Hey guy's wondering if you could help me out with this problem with my trans. My trans started hunting 3rd to 4th again so I checked the tps sensor voltage and found that it was very eratic as you moved the throttle back and forth so I replaced the tps and was hoping for a fix to the problem but it still hunts between 3rd and 4th. i checked the VSS and found that it was cracked and basically falling apart so I figured might as well change it hoping that was the problem,no luck! The one thing that is weird is that it seems as though if it is raining the truck doesn't do the hunting for the gears and works right maybe just a coincedence I have not a clue,Also my service manual sets the voltage for the tps at around 1volt I seem to remember that when I put the first one in 3 years ago that I set the voltage at . 75 for the base voltage . Thank's for any suggestions and Idea's
Joe
Joe
