This Rotten-Ratch-A-Fratch... ... :-{}
Cruise quit a while back... ... When cruise turned on, light comes on and after 20 sec it goes out. This causes multiple engine starts to accomplish the troubleshooting... ...
Pulled out service manual... found switches in steering wheel bad(Ohms check), so replaced them. NO FIX... I even measured the switch continuity from the PCM plug and the wiring checks good. .
Did the voltage and ground checks to the speed control servo... ...
With engine and Ign off I have a good ground at pin 4 of the wiring harness.
With engine running I have 13. 7 volts on pin 3 of wiring harness, apply brakes and 13. 7 volts disappears. With pin 3 of the wiring harness jumpered to pin 3 on the servo I have 13. 7 at pin 1,2, and 4 on the servo. Vaccum measures 25" hg at the servo.
Everything checks good in accordance with the service manual. :{ :{
Do I have a PCM problem in the speed control circuits? Everything else works OK... . AC, TACH, OD Shift, TC Lockup, etc. I strongly suspect the PCM since the cruise light goes out... . which suggest a voltage loss.
What is your thoughts????
HELP! HELP! I have pulled so much hair out I'll soon be bald... ...
