Engine/Transmission (1994 - 1998) Another Injector Question
Engine/Transmission (1998.5 - 2002) Lift Pump - Borrowed Time?
HOWDY...
I'd like to use the 370's marines ,, But I don't really want the "SMOKE ISSUE",,,What is a good comprise for up grade?
I am a mostly stock 98 twelve valve with 5" exhaust and K&N FILTER.
What size injector is in the stock truck?? HP?
A friend has a set of MOPAR... PT#-R438651... Any idea what these are??
THANKS GUYS... .....
Mike In Maine :D
I would just go with the 370's. If you drive like a semi-sane person you should have no problems with smoke. I can drive my truck with virtually no smoke, or I can block a 4 lane highway with thick soot if I choose! As long as you can control your "happy" foot you will not have smoke problems.
Is your truck an auto or manual? The '98 5 speed is the 215 hp pump/injectors and should have 181 DV's.
ChillyDog,,,,,,,,,,,,,,
THANKS FOR THE GET BACK...
That is helpful info,,,,,
An yes I'm a 5 gear kind of guy,, :D
THANKS AGAIN...
Mike In Maine
P. S. ,,,,,,,Any one got a "DEAL" on the 370's??... ... ... . :-laf
