Installed fuel pressure guage today as per instructions from Geno's at the VP 44 schrader valve, so down stream of fuel filter, filter changed 1400 miles ago. Readings 8-10lbs at idle and dropped as low as 4lbs under acceleration. Am I correct in thinking the lift pump is on its way out? What pressures are we looking for at this point of the system?
Would like some input from all you gearheads in the know on what fuel pump set-up would be best for my application. 2001 HO 3/4ton QC LB with Banks power pac system and exhaust brake. Primary use is hauling Eagle Cap camper aproximately 3700lbs and 16' tandem wheel enclosed trailer approximately 5000lbs when loaded with toys.
I don't need more power I just want reliability and durability. I was thinking a FASS 95 gph pump located down by the fuel tank. Whats the deal with the oversized fuel lines is it worth it? Can I yank the stock lift pump and disregard electrical connections and just wire the FASS into key on power source?
Do I need special bracket to mount FASS or can just attach to inside of frame back by the gas tank?
Thanks for your input.
Bill
Bill
