LP on way out. It was replaced under warranty about 16 months and 15k miles or so ago - is that all we should expect from these things? It was the latest rendition too, p/n ending with "AA". Pressure is always 14 - 15#, drops a little when on the go pedal. I've never seen it below 11 @ WOT since installed new LP & gages.
Monday night:
I hope I didn't do anything to prematurely screw it up? Here's why I mention this, running real low on fuel today, below "E". I get home not wanting to run dry on the way to fuel up, 12 miles away, I siphon a gallon of #2 from the heating oil tank. Tank is inside above ground less than 4 years old, with fresh fuel delivered less than 2 months ago. I made sure hose was 3 - 4 inches below fuel level and no where near bottom used clear hose - no dirt water etc. Check pressure upon start up and as usual periodically as I’m driving, it's normal. While fueling I leave it run and check all the under hood and all over stuff. I’m not more than 1 mile from home and notice an unusual flutter on the "A" pillar, FP @ 5# !$&*?]!. Here's the best part - get in the driveway let it cool to 300 EGT then shut down. Turn key to "on" . . . nothing, no sound no psi on gage. Bump key to jog starter . . still nothing. Start up and goes to about 14# fluctuates a 1/2 # or so for 15 - 20 seconds then drops to 5#. Same scenario 3 times? LP Bit the Big One, right?
So any comments on the dyed #2? This couldn't have screwed anything up . . right? It’s the same stuff, just dyed right? Or is this just a coincidence? We use #2 home heating (dyed) in the 900HP Cummins for the emergency generator @ work.
Tuesday:
This morning all's fine until truck starts to warm up then drops to 5-6#. As I drive along I notice back to 12-14#, then after a while 5-6#. This business repeats itself 3 or 4 times on the way to work, which is a less than a 5 mile ride . I recall hearing something about a recirc valve in the VP-44 that sometimes fails and causes low LP or am I mistaken? (108k miles purchased w/75 not sure if orig VP or not) I doubt that it's the gage but, I’ll check w/mechanical one tonight to be sure.
Tuesday afternoon:
Cummins Power Systems - Bristol, PA Part numbers below are for model ISB215;
LP #3990105 $167. 39
180 Stat #3954194 19. 07
Total $197. 65
On the way to Cummins & home psi kept playing hide and seek 5-6# then 14-15# sporadically and for no reason at all? When the psi was @ 5-6# it would increase to about 7# when coming to a stop – full load of fuel + stopping force = extra psi?
sorry so long - looking for any info if the LP is on it's way or should I look @ VP44?
Monday night:
Tuesday:
Tuesday afternoon:
Total $197. 65
