Another newbie fuel question
Mud Flap Laws
Horsepower wars
Howdy all!
I did a quick search on jet fuel and didn't find much on the subject.
What is the difference between jet fuel and diesel???
My brother works for an aircraft place that paints and refurbs interiors, I guess they have to drain fuel prior to doing much of the work. FAA regs don't allow them to put it back in after draining. ????
Anyway, he got ahold of about 50 gallons of it, most of the 50 gal we will probably burn in tent stove while elk hunting. Can't wait!! Was just wondering, any similarities to #2.
just wondering?? I would have to be real convinced it was OK before adding it to truck, no desire for my baby to develop an afterburner. Would be cool for tailgators though! :D
JJ
Jet A is just #1 diesel (kerosene) that has been highly filtered, don't want your fuel filter plugging at 30,000 feet! That's probably why they don't reuse it. It is ok to use it in a blend with #2, that's what you'll get at the pumps in the northern states winter. It will work straight but should be used with an additive because of it's low lubricity, especially on fuel lubricated 24 valve injection pump. As Chad said you will get worse fuel economy and performance with it. If I could get it for free I'd use it, just add a lubricity additive designed for diesel fuel with it. Blend it also, I'd go for 50%. Don't add motor oil or ATF, they aren't designed to be burned.
TDR kicks a$$!!
Chad, illflem, Thanks fellas!
Interesting! I will check the TDR (links) retailers for an acceptable additive. Toss a bottle (or two) in the tool box just in case.
Hey Chad, nice web site, very informative. The site should be required reading for 1st time diesel owners!
:cool:
JJ
I had no idea what made a diesel work until I started looking into working for CAT. I looked all over and no one had any info on diesel engines that was understandable to a new guy. I decided to start keeping notes, and once I had a notebook or two full, I took some of the stuff and made a web page.
I am glad I did it. I wish I had the time and resources to change it around all the time and put more stuff on it for everyone. Its been fun. I am glad you like it. Let us know if you ever have any questions, and someone here will have the answer for you.
