Another newby
Diesel Dynamics DD2's and 30 mpg!
Has anyone experienced this?
Let the hazing begin... I've converted from the dark side "Chevy", to join forces with the rebel force and I don't know why I waited so long. A fresh 2001. 5 6 speed eth, extra features, DD stage 3 injectors, EZ box and a Jardine exhaust system. Almost too much fun to drive, tailgaters beware hehe. . Hi to all the Nor-Cal boys and Special thanks to Blair and Nowel for waking the beast. JP
Hey smokescreen, good handle when you "get it in" at low boost. Great way to keep the riceburners off your tail. Welcome aboard !!!
Scott W.
White 2001. 5 3500 ETH/DEE 4X4 Quad cab SLT,tow package and camper prep,Husky liners front and rear,DiPricol pyro,boost and oil temp gauges,Edge EZ,Psychotty air,Bully Dog stage III injectors,ATS 3 piece manifold,HX40 turbo,4" BD exhaust,4" BD E-brake,McLeod clutch,Mallory 4150 lift pump,Mag-Hytec rear,Mopar tonneau,Lund bug shield,PM tractor utility back up lights,Penda bed mat and blow by bottle is bye bye !!! I love the smell of diesel in the morning, it reminds me of... . VICTORY !!!
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089608" TARGET=_blank><font color=red>My Truck</font></A>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089604" TARGET=_blank><font color=red>THE SAINTS</font></A>
Howdy Smokescreen. That's gotta be one of the #ad
est handles I've yet seen on the TDR. I live up near Placerville on #50 towards Lake Tahoe.
Are you going to the TDR meet in Modesto April 7th? I'm having 4" Jardine exhaust, fuel line upgrades, DD Stage 3's and boost module installed by Nowel and Brandon #ad
Hope you can make it.
Tom
Tom Golden
Godzilla: Patriot Blue 2001 2500 SLT QC 4X4 LWB ETH/DEE, Tow & Camper packages, 3. 54 Ltd. Slip, 4 wheel disc ABS, Isspro EGT/boost gauges, black SmittyBilt nerf bars, K&N RE-0880 & pre-filter, no silencer ring, Armacoating bed liner, TDR decal, Jack holiday antenna ball
NRA Life/CRPA/El Dorado #26 F. &A. M. of California
Smokescreen,
Welcome to the TDR! Lot's of great folks/good info here. I'm kinda new myself, I'm also a 2001. 5 ETH owner. Talk to me about the DD 3, EZ edge combo, I'm going to add a box pretty soon, probably the EZ, followed by injectors. I was planning to be a little more conservative on the injectors, but if there's no downside with the 3's, may as well "go for the gusto". In your opinion, is there any downside to the DD 3's e. g. driveability problems, cruise control functionality, excessive smoke etc. ? I know the clutch won't last, but thats probably the case with virtually any mod. At least with the SB clutch there's an affordable solution to the ETH/DEE cllutch problems.
2001. 5 Flame Red 2500 4x4 Quad SLT SB ETH/DEE 3. 54LS 241HD
Howdy Redram, the only issue with the stage 3 injectors would be smoke, although there is a way to drive it without smoking. If you don't romp it when your below 2000 rpm, your ok. Freeway and hills does'nt seem to be an issue. Definetely worth the power, out of the rear wheels it jumped from 200hp @ 400lbs. to 320hp @ 650lbs. bpine knows quite a bit about these things. You might want to ask him the same. The South Bend clutch on is probably what your going to need, If you're interested I can dig the # up. . Take Care
hey smokescreen looks like you are ready for my twin turbo setup ( when its finally done) after all there is no such thing as too much power just to low of a gear
2001. 5 ETH/DEE 4x4, DRW QC DD3's, EZ, HX40 machined out for more flow, Custom 4" exhaust turbo back staight pipe with 5" chrome tip in front of rear tires,spa's, mcleod clutch, fuel lines,mag hytech rear end cover,psycotty air system,relocated blow by bottle,Lucerix power heated mirrors,more to come
Hey Wiz, let's just borrow one of those tractor motors you got, how about the one with 3 turbos... Nowel has his twin set up running at the present time, looks very nice!! would'nt mind it myself.
Hey Brandon, the south Bend is a **** good clutch. Definetely does not slip, with 1500 miles on it there still is a little chatter but that only comes with lazy clutch work and at the rate it's been breaking in another 1500 miles and it should be gone. Pedal feel almost feels like stock but engages much sooner, great feel!!! I say go for it, make sure you get the clutch with the full feramic lining. Take Care, JP
Hey Smokescreen! What is agoin' on??
You are the respected holder of several diesel records in the NorCal area. Ram Runners meeting on Tuesday, bought truck on Wednesday, Bombed on Saturday! #ad
No messin' around, just do it! You worried about extended warranty coverage... NOT!!!
Bravo meistro #ad
Nowel/Performance Diesel
hey if there is to be any soot thrown it will be me I can bring something down that will make any diesel pickup look like its burning gasoline #ad
I know thats not fair 1800 hp out of a 478ci engine but hey in the hp game who cares about whats fair #ad
hopefully we don't break anything this weekend I want to try to get one of the tractors to brandons
Good luck Kevin this weekend. . oh did you get the pump to turn off so you will not drive the tractor and sled home right thru the hills before shutdown. . #ad
[last week he had the sled weight full foward, sled brakes locked up, tractor brakes locked up and still pulled thru the end of the track and barriers]
And a correction for HVAC he ties the record
[even though he did more the I we both were 3 days old on first BOMBing mods. . remember Tulare, mine was 3 days also, I think Wiz1 was close also] #ad
anyway JP come on over to Brandons so we can swap lies and BOMB some more, [adding HX40 and 4" exhust to mine]
yea we switched injection pumps around the other tractor is still in pieces so we robbed the injection pump out of it the only catch is the one that stuck was set to put out about 800 to 900 cc's this new one is putting out 1100 cc so that sucker will flat boogie at ripon we only made 100 lbs of boost and went down the track at 3500 rpm so that tractor was running sick also stuck a plunger in the pump so the engine was running on 5 cylinders we got her ready to roll now though
Well I'll be packing the snow dirt and sand down there till the last storm is done. . then spend two days detailing... any offers of detailing help #ad
oh lets not forget the damnnn bee's are a flying now #ad
just can't win . . at least I have a 100 mile view #ad
Hey Rock Tumbler I have just what you need in my garage. A big box of soot additive that should bolt right on. Hey Gary wait until you see Jason's truck it is one of the nicest trucks you will ever see, it just doesn't get any cleaner.
I have no dought little brother is going to catch up. Little brother has only had his truck a month and is well on his way. #ad
Big brother told me to keep you on coarse so I will have my eye on you. The gauges are coming down tonight.
