Over the last year, I have occasionally, but temporarily, lost a few gauge readings and had the dreaded 'no bus' odometer reading. Like most other members have experienced, there was no change in the truck's performance. Through the Fall, the problem rarely occurred. Last Monday, it came back with a vengence - no gauges, all idiot lights lit, no wipers, no external turn signals and the lights in 'limp in' mode. Again, no change in performance.
After reading as many posts as I could find on the topic, I started cleaning grounds. No improvement. Now convinced that the FCM had died, I picked one up yesterday and installed it. Again, no change.
Needless to say, I'm frustrated (and broke). I'm open to any and all suggestions as to what I should do next.
Here is what I have done in addition to replacing the FCM:
Disassembled, cleaned and reassembled the following grounds:
G103, G104, G105, G106, G302 as well as the two negative cable grounds on the engine. Only the two on the engine showed any signs of corrosion, and it was light at that.
The batteries have been disconnected for better than twelve hours twice during this process, are fourteen months old and have expected voltage readings.
Thanks in advance for your help'
Bill
Bill
