Jay__34
Nothing wrong with Rotella T; There is more than one right way to go!
I like synthetics just for the added protection if/when the oil gets really hot (300+ degrees). Because most of us don't have oil temp gauges, we don't know whats happening as it happens. I also like extended change intervals (10,000 miles - not long long term). I also like to run a 5w-30 wt and am only comfortable doing so with a high grade oil. 5w-30 gives me easier starts, better flow and a little better mileage.
I run a high grade oil filter (recommend either Baldwin or Amsoil) and leave it in for 10,000 miles.
You can run Rotella and change oil & filter at 5,000 miles and do equally well. IMHO, if towing, I would change more often; many don't but I would.
To me, frequent and high qualality oil changes are cheap insurance. What I'm focusing on is having a clean, smooth running engine at 200,000 + miles. Any system will work during the first 100,000 miles on a CTD, but what about latter on? Less expensive oils tend to form more Gum, Lacquor (sp?) and Carbon. These can build up and your engine may start talking back down the road.
