ANOTHER STEERING QUESTION?
1000hp and 200lbs torque for Dr. P's phase 2?
98.5 -3500qc 4x4 int.blue spt.pac,any1 have one?
PUMPERDUDE
Is it just me or does my truck really steer better [less drift] when pulling my travel traler with load leveling and sway bars attached?
As your front end height changes so does the steering geometry: caster, camber and toe. Find out what the alignment specs are when you are loaded and have it aligned to thoes #"s when m/ t.
Mine did the same and I had the toe changed +. 2* and made a big difference.
Dude,
It may also have to do with the extra weight on the axle. The equalizer bars on your hitch transfer some of the trailer's hitch weight to the front axle.
I kind of doubt that this is the reason, but it might be worth considering. I would guess that the change in geometry is more likely the reason.
Loren
2000 Quad Cab, 4x4, short bed, six-speed: U. S. Gear exhaust brake, MileMarker Select Drive viscous coupling, Velvet-Ride spring shackles, Painless Wiring circuit box, Optima yellow-top batteries, Super-Glide 5th wheel hitch, Reese folding ball gooseneck hitch, Drawtite front hitch receiver, Tekonsha Sentinel brake controller, Westin nerf bars, Clarion sound system
1995 Standard Cab, 4x4, long bed, automatic: Firestone Ride-Rite air springs, torque converter lock-up switch, 4" cat-back exhaust, Reese 20K 5th wheel hitch, Reese gooseneck hitch, Hayes Micro Control trailer brake controller, 100 gallon bed-mounted fuel tank with 12 volt electric pump & fill nozzle, Swiss Cap fiberglass cap
PUMPERDUDE,
Most heavy duty trucks/vans handle better with load on them(carrying or pulling).
Bill Thomas
Missouri Mule - 96 Wht 4X4 ST CC,5 spd, 3. 54, 8 ft bed, 1 ft high cheater boards.
99 Freightliner bl/wht FL60 ISB-5. 9 24v,215 hp,520 tq,6 spd, 3. 59 nsr,16 ft box, 19. 5 tires,Wt/gvw 11,000/23000
