I did a search under user name HVAC for lift pump and did alot of reading which has changed my opinion on how the system really works.
Ron Duncan posted some information he got from the shop manual which got me to thinking. He also asked this question: It doesn't make sense that the lift pump puts out 10 psi and the injector pump overflow valve opens at 14 psi and 70% of the fuel is supposed to be returned to the tank? Can anyone explain this?
I think I can answer this. First, the lift pump is not opening the overflow valve. It doesn't have the required pressure. The injector pump is the pump that is delivering the pressure required to open the valve. Now in english. Lets say (for example) the lift pump is providing 10 psi of pressure. It is moving a large amount of fuel through the fuel lines in order to achieve 10 psi. The injector pump however is pumping the fuel through much smaller passage ways inside the injection unit, creating much higher pressures. Therefore opening the overflow valve and returning roughly 70 percent of the fuel back to the fuel tank.
Remember PUMPS do NOT create pressure, RESTRICTION does. Example: when you have a dirty fuel filter, the pressure on the fuel tank side of the filter is higher than on the injector pump side of the filter, because of the restriction in the fuel filter.
The manual says that the VOLUME of the transfer pump (lift pump) will always provide more fuel than the fuel injection pump requires.
If this is correct then a pressure guage placed just before the injector pump that is reading only 1 psi under any load condition tells me that the lift pump is providing more fuel than the injector pump can use, because only 1 psi means the injector pump is under positive pressure from the lift pump.
If you are seeing a negative pressure before the injector pump in any load or throttle condition, then the injector pump is actually sucking on the lift pump trying to get more fuel, which I think we all know is a life threating enviroment for the injector pump to operate in.
Now I have a question. How can we find out the pressure comming from the injector pump? We know it is at least 14 psi if it is keeping the overflow valve open and returning 70% of the fuel back to the fuel tank. Also by returning this fuel and keeping the overflow valve open it is performing the task of cooling and lubricating the injector pump. Actually on second thought this is probably not something we even need to know.
Now we just need a more reliable pump that will copy the exact performance of a new properly functioning lift pump. That shouldn't be too hard to find, should it?
PS. With this new found belief in the way the system works, my previous post about using a fuel pressure regulator before the injector pump is totally wacked. Please dissreguard my previous transmission.
Wayne
Wayne
