I was on the Cummins web page and saw this on anti-freeze. The link is below the Q&A.
Q:"What does antifreeze do, and what are Cummins recommendations on concentration?"
A: The primary purpose of antifreeze is to lower the freeze point of the coolant. Additional performance characteristics of coolants that are affected by the use of antifreeze include boiling point and vapor pressure. Antifreeze decreases vapor pressure which is very beneficial to the reduction of cavitation. This characteristic is the primary basis for Cummins requirements for increased SCA levels when antifreeze falls below 40 percent by volume. A 50/50 mixture of antifreeze and water provides optimum boiling point and freeze point protection for engines. Antifreeze concentration in excess of 60 percent must never be used since it increases the possibility of forming cooling system gel which results as silicates precipitate out of solution. However, concentration of antifreeze less than 40 percent increases the possibility of coolant freezing and liner pitting. Therefore, Cummins recommends an antifreeze range of 40 percent to 60 percent. Fluids presently used in antifreezes are ethylene glycol (EG) and propylene glycol (PG). Diesel engine antifreezes have primarily used EG products because they are less expensive than PG products. Some antifreeze applications require less toxic substances which have driven the use of PG. Engine-related applications of PG primarily have been applications where environmental concerns have disallowed the use of the more common EG products. For more information, refer to Cummins Coolant Requirements and Maintenance, Section 7, Bulletin 3666132.
http://www.cummins.com/na/pages/en/products/dodgeram/faq/answers. cfm?uuid=93066F3D-04CE-11D4-98530004AC33EA57
1999 Dodge Ram 3500 Quad Cab 5 spd; 4:10 LSD rear; Mag-Hytec diff. cover; US Gear EGT and Boost gauges. Amsoil foam air filter and synthetics from nose to tail.
Cummins Power, don't leave home without it
