Engine/Transmission (1994 - 1998) any difference in gen 1 and gen 2 blocks?
Engine/Transmission (1998.5 - 2002) cam position sensor
2nd Gen Non-Engine/Transmission Lift Coils?
I have a 96 3500 that is getting tired at 290 k and i have an engine out of a 91 that i bought at a junkyard. I would like to start building the 91 shortblock and then use it in my 96 so i can take my time building the short block and still minimize down time. Are they the same block?what parts are interchangable and which are not?Is there a preferred year or casting for the gen 2 engine?
As far as I know the motor mount bosses on the second gen are different. So I don't think it will work. Have a closer look. To use the p-pump you should change the front timing cover ( big job).
