Any help for this newbie??
anyone running propane injection?
Buddy lost a motor, bad oil filter ........ $12,000 fix!!
I recently joined TDR and posted this a while back and have gotten no replies. Any advice will be greatly appreciated.
"When driving with moderate throttle sometimes the engine hesitates in half second intervals. It is a subtle hesitation that feels like little bumps in the road. It happens most often while using cruise control in 6th gear when going down a hill at low rpm (1600-1900rpm, 55-65mph). The truck has 90,000 miles and has been doing this for about 5,000 miles. I have also noticed that sometimes when idling, the engines hesitates for a split second which is very subtle and is probably only noticeable to me because I am very accustomed to how the engine usually idles.
One other thing which I know is likely unrelated: The engines is now running a few degrees hotter than it used to. The gauge seems to sit in the middle at 200 degrees while it used to sit slightly to the left of middle which I would estimate was around 195 degrees.
The truck is a 2004. 5 4wd, 6th speed manual which has only seen very light use, mostly long highway trips at 62mph with no load. The truck has always been properly maintained and still has the hesitation problem with a new fuel filter.
What do you think the problem is and what do you advise I do?
Also, do dealers get out of warranty work if after market fuel filters were used instead of the overpriced Mopar filters? "
Thanks very much, Mark Varelas
San Antonio, TX
To the first part of your post I am only guessing but it sounds to me like your cruise is cutting in and out as it sounds like you may be in a "coast" mode. I get this happening in almost any vehicle using cruise and going down hill. As for the rest of your question I have no idea. Too much light loading. These engines like to be worked and really respond to long hard pulls. Seems like the guys that drive them like they stole them have less problems.
I had an issue like that once as well, I was on a 700 mi road trip, cruze on and doing about 80, truck had a quick studder, and went no problem after that. About another 1000 miles or so it did it again(on my way to airport). the truck lost #3 injector and spit diesel and oil all over the highway. have your local shop check your injectors.
