Attention: TDR Forum Junkies It's not a difficult install unless you are doing it alone. Follow the directions closely. Measure precisely and use a small bit to make a pilot hole. Then follow up with a holesaw. Once the whole assembly is in place and the bolts are tight, drill the safety chain holes from the bottom up, using the hitch as a template. If you are doing it alone, put a 2x4 across the bed rails and use a ratchet strap or come a long to hold the hitch in place while you position it and start the bolts.
