Any intercooler gurus out there?
getrag transmission
Do I need the waste gate hooked up!
just received a catalog from spearco intercoolers... they've got all sorts of cores and hard tubing, manifolds, boots etc...
anyway my question is this, what is a good flow rate for my application(see below in sig). . they have many diesel application cores... how many CFM do i need to flow well enough to see substantial cooling and performance gains?( 4. 1L to 7. 5L diesel application cores flow from 700 CFM to 1500CFM)
second question: what is a good charge efficiency? ie... . 80 . 90 etc????
also... what do i need to keep the charge pressure drop low?
thanx in advance
joe
1990 w-250 4x4 cummins 5. 9,NV4500,tweaked injection pump, 16cm2 housing, 3"
JRE exhaust, 4. 10 gears
Would you by any chance have A phone number for that catalog? I think that would be A book definnately worth looking at. .
in case u didn't get my email... 818. 901. 7851... got my catalog within 5 days... some neat stuff like water injection kits and some liquid to air intercoolers
Or on the web at: www.spearcointercoolers.com
Dave
91 W-350, LE,4x4,4. 10 gears, 5 speed, 4" stack exhaust, 16 cm housing, full fuel-28 psi. , boost gauge and tach, Borgeson,
Air lift bags, Softride
kit, Ranger 6900F-turbo
(radio). PW injectors
[This message has been edited by Dman (edited 01-20-2001). ]
you can calculate your CFM by taking the CID of your engine, dividing it by 12^3 to get it in cubic feet displacement and then multiplying it by the governed RPM that your engine is set to. Take this number and buy the next biggest intercooler.
91. 5 CTD, 5" Stacks
One small correction to unclebilly's formula is to divide the result by 2 because it takes 2 crankshaft revolutions to displace the CID of the engine when the engine is a four stroke.
Interstingly, for our 359 CID Cummins engines it just happens that theoretical CFM is 1/10 the RPM. So if the engine is running at 3000 rpm with no boost is will require 300 CFM theoretically. However because of the turbo charger the actual airflow through the engine may be twice or more than the theoretical amount. Therefore triple the calculated CFM (about 900 CFM). The pressure drop to obtain this flow should be less than 2 psi.
'93 W350 Club Cab, Bright White, 5 sp. , 136K, Factory Options: LE package, 4. 10 Limited Slip, 7600 lb. rear springs, tachometer, front stabilizer bar. Mods: Banks stinger plus, Linex bedliner, 25,000 lb gooseneck ball, 10,000 lb receiver, Tekonsha brake controller, POWER WAGON injectors-WAY faster than stock!.
Cummins diesels take very small intercoolers. Powerstrokes have very large ones because they have more displacement and run at higher RPM's. The stock Dodge unit is adequate, but probably less efficient than the Banks unit, because Banks mounts them in FRONT of the AC condensor! I'll take the cold AC and a little less intercooling here in South Florida! If nyou REALLY want to cool it, use one of the trick units that uses the AC compressor to cool down the inlet charge!
http://coffeewithJesus. homestead.com/web1.html 89 1-ton, Amsoil System 3000 5-30,K&N air filter, cleaned-up exhaust, Dynomax straight-thru, rebuilt pump, thermostatically controlled twin 14" Permacool electric fans, intercooler), modified 518 OD transmission, Gear vendors OD controler, R-134 refrigernt, louvered front fenders, 93 aftermarket smoothie grille, new Dupont Chromacolor black, black-and-red rubber rubstrip, black headlights, powdercoated bumpers; 78 35'Avion, 93 Lance 900 slide in with generator and power jacks. To see my truck, Click on: <A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1169022&a=10097213
Jesus" TARGET=_blank>http://albums.photopoint.com/j/AlbumIndex?u=1169022&a=10097213
Jesus</A> saves!
Thanks much Jsimpson for mentioning that the Banks unit is in front of the A/C condenser. If that is the case with a '93 kit my Banks intercooler project (tax return financed) is cancelled.
There definitely seems to be some confusion. The Banks intercooler for a ’93 application mounts directly in place of the factory intercooler, behind the A/C condenser and in front of the radiator.
Peter Treydte
Director of Technical Communications
Banks Power
