Cosmo, I think you have your oils reversed. CI was the excellent oil, CJ is required on the latest engines.
eh. It was late, but you're correct.
CI-4+ = good
CJ-4 = bad.
I think you are grossly exaggerating and misinterpreting many of your asssertions.
I trust Cummins, Inc. a lot more than website engineers with "better ideas and understanding. "
My EGR was clean as a whistle at about 70 to 75k miles. Some of the fuel dilution reported by members is probably caused by incomplete crankcase oil drain when changing oil and exaggerated by short trip grocery getting duty for the truck.
I don't remember noticing a change in the service life to overhaul claimed by Cummins for the ISB6. 7 engine compared to the ISB5. 9.
Are you another 5. 9 owner criticising the 6. 7 without owning one?
Oil dilution is caused by not draining the oil?
No. Oil dilution is caused by fuel getting into the oil. There are those who didn't drain their oil and found their crank cases over-filled, but that's not what I'm talking about. I'm talking about the guys who took samples and had them tested, with fuel concentrations of 20%+ returned on their analysis.
Am I another 5. 9 owner? No, I'm a 6. 7 owner who actually opened their intake manifold up and saw the result of 45k miles of EGR - between 2-5 mm of carbon buildup EVERYWHERE in the intake tract. It took about 15 cans of throttle body cleaner and a bunch of scrubbing just to get the intake air horn clean.
Where on earth could this contamination come from? Carbon buildup is awesome, right? Makes things run well, makes them run longer.
Did I say that Cummins reduced their overhaul intervals? No. I haven't been able to find it printed anywhere. I'm sure the move to block casting in China helped though.
Let me ask you something. If the EPA says "you do these things or you don't sell engines" don't you think that the manufacturer is going to do whatever they're told, even if it's not in the best interests of their product and consumers?
Yeah, same with oil manufacturers. They claim the CJ oils are an improvement over the CI oils, but read between the lines. Who in their right mind would advertise "Our new oil isn't as good as our old oils, but this is what you get".
Do you know anything about the EGR and DPF systems?
You're lying through your teeth about your EGR being clean. It would be about as clean as the tailpipe on a pre-DPF truck at the very best.
Cosmo,
You are simply an ignorant man. In a group where particants actually met face to face instead of slinging insults in an internet forum you would be known as a loudmouth.
You may not understand that C&C trucks are tuned for different hp and tq, have much less restrictive emissions equipment, and no history of sooting components.
I put you on my ignore list so I won't be reading anymore of your stupid comments or accusations of being a liar when you post someething stupid and another member embarrasses you.
but it is IMPOSSIBLE to inject exhaust directly into your intake and not have it soot up.
so much for my truck trade:-laf:-laf:-laf
Cosmo,
Congrats!
I was able to find a lower console center seat in the local cragislist adds and add it. It's a great place to keep a pistol.
I like that, but don't think I have the room required to keep it there.
Besides, that's a Toyota!
Isn't the exhaust brake awesome. 98K miles and still have the original brake pads, I'm not kidding.
Ken
