y-knot said:I pretty much think a filter is a filter, as long as they adhere to the manufacturers specifications is there really any advantage? I know they would like you to believe there is.
amsoilman said:Ok, here are the Oil Filter specs. for Cummins tested per Cummins Spec. #10634.
Efficiency 59. 5%
Capacity 54g.
Here is the spec on the Amsoil/Donaldson Oil Filter tested as per Cummins Spec# 10634
Efficiency 98. 7%
Capacity 125g
Wayne
The exclusive Donaldson synthetic media design results in a full flow filter that delivers extraordinary performance with greater efficiency, capacity and flow. Donaldson Endurance filters are 98. 7 percent efficient when faced with 15 micron contaminants, and they are 50 percent efficient when faced with seven micron contaminants. The smallest particle that can be seen with the naked eye is around 40 microns.
Gary - K7GLD said:Engine lifespan back in the 50's and 60's was averaging about 100K miles - today's GAS engines frequently double and triple that mileage. The 2 most singular reasons for those increases, is better quality lubes, and improved lube filtering.
wlowe said:After reading the above posts I've gathered the following info:
Fleetguard filter LF3894, (from previous post) : LF3894 is a Synthetic Media (Stratapore) Round shell, 10 Micron at 60% efficient, 30 Micron at 100% efficient.
Donaldson Endurance, (from Amsoil website) : Endurance oil filters provide filtering efficiency of 98. 7 percent at 15 microns and 50 percent at 7 microns in accordance with industry standard ISO 4548-12. This is the best rating in the industry.
So, conclusion is, both are synthetic, Fleetguard is 60% efficient at 10 micron and Donaldson is 50% at 7 microns. Is the Donaldson worth over twice the cost of the Fleetguard LF3894, you tell me?
How much is a "recommendation" worth?amsoilman said:Will "Fleetgaurd" recommend 25,000 miles/one year change interval on their filters?
RustyJC said:How much is a "recommendation" worth?
Rusty
OK, Rusty. Are you telling me its OK to have all your additions on your truck and Dodge/Cummins is going to honor your warranty without ANY questions asked? Even IF the Manufacturers of your additions recommends them?RustyJC said:I'm sure you're trying to make a point regarding my truck, but I'm not getting it, so here's mine:
Warranties have value. Recommendations don't. What is amsoil prepared to do if I follow their 25,000 mile/1 year recommendation and things turn to apple butter? If the answer is nothing, then how valuable is that "recommendation"?
Rusty
My question was rhetorical and had nothing to do with my truck. And, no, I've never been back to the dealer for any problem, warranty or otherwise.amsoilman said:OK, Rusty. Are you telling me its OK to have all your additions on your truck and Dodge/Cummins is going to honor your warranty without ANY questions asked? Even IF the Manufacturers of your additions recommends them?
Unless I misread it, that's amsoil's lubricant warranty. We were discussing the use of their filters according to their 25,000 mile/1 year "recommendation". I didn't find anything that addresses that product or circumstance.amsoilman said:To directly answer your question with regards to Amsoil's warranty, you can see the Amsoil WARRANTY here.
