any one change dash lite bulbs ?
need help from fabricators.. invention idea
MAP sensor voltage?
It's easier than you think. The trim panel around the dash just pops out, sometimes it takes a good tug, but it will come. Then there are 4 screws I think holding the cluster in, remove them and the cluster pulls right out. Turn it around and your looking at the bulb sockets. 30 minute job if you have the bulbs.
Hope this helps,
Dave
I am just getting ready to this, have one burnt out around the speedo. I can only find them at the dealer, part # 4839738AA. You will have to pull off the center and headlight sw benzle first
Getting the dash instrument pod out was a pain for me. It would not clear the space between the top of the dash and the steering column no matter where I placed the tilt steering or how I angled the pod. I ended up having to remove the plastic shroud around the column to get it out. The second issue was getting my monster hands behind the dash pod before removing it to unhook the wiring connectors. There was not much slack in the wires and the metal behind the dash carved up my hands pretty good trying to unplug the three connectors. About six of my bulbs were burnt out. Only cost about $1. 25CDN each at the dealer and some blood and cursing.
