Any practical ways to improve 1st gen 1 ton brakes?
mpg's improving, slowly, but surely
mine suck with a load!
http://coffeewithJesus. homestead.com/web1.html 89 1-ton, Amsoil System 3000 5-30,K&N air filter, cleaned-up exhaust, Dynomax straight-thru, rebuilt pump, thermostatically controlled twin 14" Permacool electric fans, intercooler), modified 518 OD transmission, Gear vendors OD controler, R-134 refrigernt, louvered front fenders, 93 aftermarket smoothie grille, new Dupont Chromacolor black, black-and-red rubber rubstrip, black headlights, powdercoated bumpers; 78 35'Avion, 93 Lance 900 slide in with generator and power jacks. To see my truck, Click on: <A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1169022&a=10097213
Jesus" TARGET=_blank>http://albums.photopoint.com/j/AlbumIndex?u=1169022&a=10097213
Jesus</A> saves!
Get some electric brakes or surge brakes for your trailer.
89 D-250 LE 5 speed 3. 55 Limited slip, K&N, straight piped, Boost/Pyro. & 16cm2 215K and still going.
i have no problem w/ 93 4x4 duelly
except vac booster is bad its either makes brakes to tiuchy or to hard, ill replace it soon' as 4 brakes, except 4 that mine stop good, keep rears adjusted every 3 months, best to pull drums, flush brake fluid, w/ a rev flusher, the guys on
tv sam m says these r best, anyway use dot 5 the best u can get for fluid
my fronts were nre at 100k when i bot trk
now have 135k still fronts r new.
yes trailer brakes properly set up work well, bill
1993 w350 ex cab, banks,nv 4500 in
open exaust, pw Injectors are in. Big rig flaps,tach soon to be in. Its loud and goes ok, for a 93,only beat 1 pwr strk furd. 2 optimas,
love driving it!
