Template errors
  • Template public:thread_view: [E_USER_WARNING] Method canConvertThreadToRmsItem is not callable on the given object (SV\SearchImprovements\XF\Entity\ThreadCollab) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsReview is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsQuestion is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsFaq is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsEvent is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsLocation is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsCheckIn is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
any special tools needed for....
Novice question
Auto transmission line pressure
track bar replacement? thanks. scott. i'll search first... . but... . how do i know if my track bar needs replacement?
thanks..... scott.
Easiest way to check the bar is to crawl under your truck and have someone slightly turn the wheels back and forth. If you see any movement in the drivers side ball joint end of the bar it's shot. A hand sledge is the only special tool needed for replacement.
thanks illflem. i saw your post when i did a search. i wish i had access to your library of answers. i have had my front end aligned but i still have a pull. i have rotated the tires. the tires are michelin and i don't want them ruined. i will try a new track bar if needed. thanks.
illflem,
do you recall, by chance, the part no. of the napa track bar. i couldn't find one on the napa online site. no suprise. thanks. scott.
Scott, my Napa receipt says 272-4229 for the p/n, $179. They call it a NCP trac bar (no K) if you want to try a search. Replacing the bar and steering stabilizer totally eliminated my truck's drifting and tire wear.
