I'm sure I read in my Cummins manual somewhere, that their torque specs are the same per given bolt size. Like 15mm bolts-10mm bolts are all 18ftlbs.
But anyway by book says 18ft-lbs. Also says 'be sure to fill the joint between the pan rail, gear housing and rear cover with sealant. Use Three Bond 1207-C. ' Whatever that means.
