pop the pump gear off, then after the cam and crank are back in check, use the engine timing pin to set TDC, then use the pump timing pin under the acorn nut at the back of the pump to set the pump timing, put the gear back on (after thorough cleaning), tap it on with a hammer and a big socket, then undo the pins, and tq the pump nut.
The pump timing pin will be under that big nut, pull the whole thing out, it's a plastic pin, if you flip it around in the nut, you'll see it has two tabs on it, turn the pump over by hand until you can see the tab inside the pump line up with teh hole, seat the pin back in and put the nut back in, then install your gear
-Will
-Will
