Any Twin Turbo kits that utilize the stock HX35?
DT-466 Turbo question....
Did I learn my exhaust system lesson?
Are there any kits available that utilize the stock HX-35 turbo as one of the 2 in a pair of twin turbos?
How well do they work out? Quality/price?
Not looking for more than 450HP (ok might want 500 some day), but quick spoolup and cool towing power would be nice.
Is this a realistic target? Also seems like if there is more oxygen available, MPGs should stay the same or increase?
Or should I just get a Dodgezilla and call it good?
Thanks Again!
Thanks Again!
I started with a stock HX35 in my twinset. I now have a Dodgezilla and a lot more fuel.
I am using one of Rip Rook's kits at Source Automotive. I opted to use the internal gate and I can drive the bottom turbo as hard as I choose to.
I can tell you at the low 400 level, my smoke dropped a ton, spool was actually no worse than before (including upgrading from a 12cm housing to a modified 14), and temps were even better. I get 23 mpg unloaded box off.
best part is, I can tow as much weight as I want and still have great spool for the 285s and 3. 54 gears with a tight auto.
Most will tell you that it is a total waste of time and energy to use a 35 in twins. But, if he need warrants it, you'll be fine.
Rip also has sets that use S300's on top, HX40's, HX35's and probably a few I can't think of. I can't speak about others twins, but if you want some more info about mine, drop me a line and I'll send you some pics. I still haven't figured out how to post pics. :-laf
Dave
J. R. Adkins makes the kits that use the HX-35. He will build them for any turbo setup that you wish to use. Very good quality and excellent guy to deal with. His phone # is below in my sig.
Thanks Again!
I think Relentless diesel does... I have no idea if they work good though, I dont own them...
The Relentless diesel kits are for the 3rd gen only 03+. Mark Kendrick makes nice kits that uses the stock HX35/B2. He is on here under that same username.
