Anybody do a N.J. inspection lately???
DC Paint Warranty
Cummins West in West Sacramento
Whats involved with this? I was always under the impression that there was no emissions test, but with the MANY changes in the past year or two, I don't know anymore. #ad
If not, do they give a "visual test" for smoke? Do they "pull a sample" to see if the fuel is red? #ad
Any advice is appreciated. TIA
98 Quad cab 4X4 2500 12 valve,5 speed,3. 54 rears, 8' bed. Boost and egt gauges but basicly stock except for a "properly adjusted" AFC. 55,000 Mi as of 8/21/00.
NRA life member. High power/IDPA.
Don't know about NJ but in California they will pull fuel from your tank--red=$$$. Currently all Fleet operations are required to do an opacity (smoke) check yearly with a approved meter on every truck over 8600 gvw and more than 4 years old. Don't worry it's coming to your home town soon.
Am pretty sure our trucks are exempt from emissions, Our shop got a letter saying that anything over 18,000 pounds is tested. On a side note my buddy owns a bus company and the state comes to them to test all there buses twice a year. He said they will take a bus with 200k on it and hold it wide open for 15 seconds to check for smoke... JB
99 Black/Agate, Quad,Long bed,4x4, SLT,Auto,HX-40 16cm2 & ATS Exhaust manifold treated to Jet-Hot 2000(Gray),DD stage 3 injectors,4 wire Blue Box,"True" 5 inch Jet-Hot Coated exhaust from turbo to Tailpipe(Over the Axle),Borla Shoot-out Muffler,Suncoast converter, BD valve body and pressure-loc,Mag-Hytec trans pan,Amsoil ATF-4,Mobil Super Delvac 1300,fuel line up-grade from lift pump to filter and from filter to injection pump,Auto meter Ultra lite gauges:Boost,EGT,Fuel Pressure,Trans Temp, Valentine 1, EZ-pass
[/B]
If the state blows one of these buses up during testing, will they pay to fix it?
Bill Lins Wharton, TX 98 2500 QC SLT,12 (the CORRECT # of)valves,NV4500,3. 54 LSD,Manik grille guard,Semi-Psychotty Air,Amsoil everywhere, Reading aluminum utility body and bumper,Optima yellow tops- silencer ring & muffler stolen.
I went through inspection at Paramus NJ in April. No emissions (diesels are exempt as long as your registration is 10,000 pounds or less). There is a stiffer brake test now, but my 96 3500 Club 4x4 aced that with no sweat. It was actually kinda funny to watch the looks I got from the other people in the waiting area as they waited for their gasoline-powered cars and the extended emissions test, while the insoector waved me over after about 2 minutes of brake tests, slapped a 2 year sticker in the windshield, and said "See ya"
One thing that is new and important: you get a printout that says you passed and what test were run - you will need that sheet in your files in case you ever have to take care of a repair that would affect inspection otherwise (eg, a broken windshield). That is your proof on passed inspection if you need a replacement sticker for any reason.
I went thru the station in So. Brunswick in May. Went right thru. No check of the emissions or fuel. Even with a bunch of trainees from Parsons going over everthing, it still only took 10 minutes.
Thanks for the replys all.
Blue knight, you a member of the MC club by that name? I used to work with a bunch of guys that went to Sturgis, Daytona etc. etc. every year. I finally got a bike, it's a honda #ad
Bill,I asked the same thing to my buddy... when he asked. . the inpector jus gave him a dumb look
