2nd Gen Non-Engine/Transmission Anybody got a picture of a 2nd Gen fuel tank?
Engine/Transmission (1998.5 - 2002) Need more power
Engine/Transmission (1994 - 1998) reverse switch on a 94 cummins
Wondering if anybody has a picture of one out of the truck? :confused:
I don't think it makes any difference but would like to see one in a truck similar to mine. (Club Cab Long Bed).
Thanks,
I'll hopefully be able to post a picture of my old tank in a day or two. I'm getting ready to install the 60 gallon replacement from Aero Tanks.
I would really appreicate this, I'm looking into a tank vent mod like Spooled-ups for the 3rd Gen's
I posted in the 12 valve section a couple days ago about venting both the humps, cause we have double humpers, at least mine does, the 3rd gens don't. would it be advisable to leave one for expansion?? and just vent the large one?
Also some thing else one should consider, the fuller the tank the more the float is going to rub on the top of the tank and give poorer readings as time goes on.
Marv.
Marv.
Is either hump higher than the other? That would be the one I would use, how easy would it be to get the shavings out from drilling? Like on 3rd gen's you can reach the back area where you drill for the bulkhead.
Once I get a picture I will have a better idea, I think I am just going to buy one of Spool-up's kits and modify it. We will see once RHerbert gets me a pic. :confused:
By the way, this one is available for a reasonable offer, sender works great!
Do you like the dandelions for that spring effect?
later,jon
Nordby said:
This should help. Out of a 1997 Extended Cab 4x4.
jon
SWEET! Oo. It looks like one of Spooled-up's kits will work like a charm on a 2nd Gen tank as well! Oo. Oo.
Just do the hump in the back because it looks a hair bit higher than other one, or you could do both with an addition plastic Tee... ... dunno I will have to think it over.
Jon thank you for the picture! Really appreciate it! ;)
