Anyone ever use "Herculiner"?
SO LONG 21468 ! ! ! HELLO 19335 !
Train Horns
I saw this stuff in Sam's (roll or brush on bed-lner material) and was thinking about trying it on my brushguard and to paint my utility trailer with? Has anyone else over used it - either on the bed of a pick-up or anywhere else? Opinions on strength toughness, looks, etc. ?
Is that the link to the guy who got the stuff on his..... ah privates? It is a must read, try not to fall on the floor.
OK . . . so now that I know not to get it on my Hootus . . . #ad
Has anyone used this, or just read funny stories about it???
I used Herculiner on my rocker panels when the truck was new(approx 10 months ago). It is VERY tough and the rocks don,t even mark it, as opposed to my 98 Ram which was always chipped and dented and required constant paint repair!!! I only applied one coat and would recommend that you apply at least 2 or three coats to get the look of the spray applied coatings. I have been spraying Armathane on the gun cases that we manufacture for 7 months now, and it is fantastic!!! When time allows I will be spraying the rocker panels over the Herculiner, and on the back side of the rear bumper, and anywhere else that is subject to abrasion.
2001 QC4x4 eth dee slt+ 3. 54 blk agate leather Warn transformer mount Hella 4000s, Hella 530 backups, Optima redtops Toro liner, jacobs ebrake, wired front and rear for Warn 9000 winch, backup lights inset into rear bumper,bumper powder coated silver vein, bedliner on 6" of rocker,custom aluminum console with Garmin Colormap GPS and EGT built in,Horton fan,MagHytec diff cover
Also in the works is a tool box,(winch, shovel,axe, tools,etc. ,) approx. 60x20x18 , riveted aluminum . 240 thick (3 layers of . 080) which I will spray to match the Toro bedliner
One of my buddies used it on the inside of his Samurai, it came out pretty good. Not as thick and probably not as durable as the spray ins, but you get what you pay for. I like it a lot better than the Dupli Color stuff my brother used on the inside of his '70 Blazer, that stuff is junk. Real thin and comes off way to easy.
Pete
'97 2500 CC 4X4 5spd Sport
'83 K5 Blazer 350 TBI (ex 6. 2), 39. 5 TSLs, 3" lift, Dana 60/GM 14 blt, Detroits
I have an Arma liner in my 89 cummins. I think this product is superior. They say , the only way to remove it is to use a grinder. This is also A hot application,it goes on at 280 degrees. This way it sticks much better. I notice that it gets very slippery to walk on if there is frost on it.
My liner didnt crack at all in -30 degree wheather like I figured it would. Well , Happy Rammin' .
2000 Dodge 2500 4x4 Cummins 5 Spd.
1989 Dodge 250 4x4 Cummins Auto. FatMac
I used the Duplicolor and m pleased with it. Use 2 gallons (that's only $100). 2 coATS HOLDS UP QUITE WELL EVEN WITH MY 3000 POUND lANCE ON BOARD.
http://coffeewithJesus. homestead.com/web1.html 89 1-ton, Amsoil System 3000 5-30,K&N, cleaned-up exhaust with Dynomax straight-thru, rebuilt injector pump, thermostatically controlled twin 14" Permacool electric fans, intercooler, modified 518 OD transmission, Gear vendors OD controler, Reese Titan 2. 5" receiver, R-134 refrigernt, louvered front fenders, 93 aftermarket smoothie grille, new Dupont Chromacolor black, black-and-red rubber rubstrip, black headlights, powdercoated bumpers; 78 35'Avion, 93 Lance 900 slide in with generator and power jacks. To see my truck, Click on: <A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1169022&a=10097213
Jesus" TARGET=_blank>http://albums.photopoint.com/j/AlbumIndex?u=1169022&a=10097213
Jesus</A> saves!
I put herculiner in my truck right after i bought it, and im undecided it i will use it again. At first I thought it looked good and held up well, but after 6 months I started to notice a place where it has worn through all the way to my primer coat. It looks like it was caused by me sliding in and out a rack i made to carry all my tools so I can take them all out at once, instead of unloading everything individualy. If i did it again, I would have it sprayed in professionally.
2001 2500 6 speed no mods yet
