Has anyone ever had or know of anyone who used or use's one of these preditor performance modules ?
this one is suppose to add 70 hp and 150 ftlb torque
Thanks Eddie
Predator Performance Module for Dodge Cummins:
Predator Performance Modules can take your Cummins to the top of the power charts by using combustion efficiency performance technology that safely burns existing fuel more efficiently, instead of adding excessive fuel to the combustion chamber like other systems on the market. This combustion technology boosts airflow, fine-tunes fuel delivery with precise air/fuel ratios, gives you greater volumes of energy during combustion and provides more power and longer engine life. This will transform your already powerful Cummins engine into a monster workhorse with an increase of up to 130-hp and a 35% boost in torque, at the rear wheels! Another great benefit that your Cummins will now realize is better throttle response and drivability with fewer and smoother shifts. Your speeds under load will increase 20-35 mph on grades of 5 to 8%.
Benefits:
Horsepower and Torque gains at the rear wheels
Up to 10% increase in fuel mileage
Safer vehicle operation
Increased engine life with a smoother running engine
Cleaner emissions due to less cylinder wash
Uses no aftermarket chip, so Predator will not void your warranty
Undetectable by the vehicle's electronic control unit
It can be ''self installed'' in only a few minutes with easy instructions.
Thanks Eddie
Benefits:
