upgrades to transmission
Rock-n-rammer,
Yes, I have the 275's and the EZ Comp and had to upgrade the transmission. Initially I had just added the injectors with the hope of stopping there for a while, but the added torque at lower throttle possitions cause the lockup clutch to slip in the 45-65 mph range. I took it very easy for the rest of the camping season (I pull a 14,000 fifth wheel), did a L O T of research and ended up with the ATS triple disk converter and valve body. It is not cheap, but what a tremendous difference!!! I now have solid lockup, better shifting, more effecient torque converter... ... ... ... better all around. It worked so well I added the EZ Comp. There are many good aftermarket transmission upgrades as can be seen by brouseing that subject, but I highly recommend ATS. Their method of increasing holding ability is much more scientific than just turning up the pressure as everyone else seems to be doing.
Getting back to your original question - yes when adding even the upgraded injectors, you should upgrade the transmission too. It is my opinion that even with a stock engine, the transmission is marginal at best when pulling big loads.
Paul H
