I already explained why once.
Why don't you ask the truck manufacturer's why they designed the lighting wiring and switches so that fog lights cannot be illuminated when high beams are on? Would it be reasonable to assume that the manufacturer's have good reason for wiring them that way?
I knew that I had something I wanted to bring up regarding fog lights and the light bulb just came on... ... .
When I went on my trip last fall to get the Freightliner Cascadia and drive it home to Maine I had noticed that in lieu of a factory switch for "FOG LIGHTS" it had a factory switch marked "AUX HIGH BEAMS" and that it worked in reverse. . the bumper mounted lights came on with the High Beams and went out when Low Beam was selected.
I just did a quick study and found the technical bulletin from Freightliner explaining how to change a Freightliner Cascadia truck from FOG to AUX HIGH lighting. This chassis uses a SAM module for electrical control which is a relative of our Dodge CAN BUS system I believe.
It boils down to changing the switch in the dash, a little witchcraft in the SAM unit and different part numbered lights that fit in the same location in the truck's bumper to make what ever set-up is desired.
I think that it must all come down to the OPTICAL PROPERTIES OF THE LIGHT USED that defines it as FOG or AUX HIGH BEAM in the eyes of the DOT.
The legal team at Daimler would not allow this if it violated federal standards.
If someone was trying to mess with you trying to run driving lights with the High Beams simply explain that they are AUXILIARY HIGH BEAMS and it is all good. :-laf
I find it interesting and have attached the Freightliner Technical Bulletin that outlines the procedure and parts needed to do it.
I know the odds of anyone on here owning a Cascadia are slim to none, I attached it just to show that the DOT law may be dependant of the type of light that is used.
Had to break it up into 5 pages to get it on here, sorry... .....
Mike.
