I've got all kinds of magnets , the sneakiest is a small round put into a piece of hose , then your not limited by over hang , also when I did my ETG probe I would spin it , it would fan out to catch more chips , then even trickier , is to put a piece of wire inside of the tube to get you to a spot nothing els will .
We have to be smarter than the problem .
My reading of tapping head bolt & stud holes is that to gauge the TQ , your need a clean even threads , every industrial eng I've come across also use's a lube , many send out with either the gaskets , bolts/studs , most of it is a molly based , the reasoning behind this is that to get the correct TQ , you do not want the TQ wrench to get any extra reading from dirt/carbon , ruff metal surface , metal shavings , the TQ is not what is put against the threads , but what is put against the shaft of the bolt/stud , also referred to as stretch tension .
t
t
