Anyone out there using EDGE A2????
Baldwin and Fram filters
Pdr-40 Vs 62/.8
Can it monitor trans temp. ??
How does it monitor all the parameters? Does it just hook into the factory ECM to read what it's reading, or does it have it's own temp probes, etc. ??
Is it possible to add other readings to it?
The Edge A2 can't monitor trans temps on the Cummins.
See the PDF about it HERE
Looks like it will only do it on the Ford 6. 0L Platinum.
You can't add additional parameters for it to monitor other than what is programmed into it. It is connected to the Juice module which is tied into injectors, MAP sensor, fuel pressure sensor and the data link connector. The only sensor it has that is stand-alone is the EGT sensor.
