Katmandu said:Anyone run a straight pipe "Dump" style exhaust ?
The type that points right towards the ground under the truck.
Yea, in (2) completely separate forums.Grizzly said:You ran this thread twice.
Forrest Nearing said:it's gonna cover the underside and back of your truck w/ soot
steved said:It will? I ran mine this way for 100k and never had as much soot as when I had an actual tailpipe.
steved
Forrest Nearing said:you must not be putting out much smoke then... ever crawl under there and run your hand over stuff?
my buddy's truck has an open downpipe after his twins, and his tailgate is black, and the rear end they pulled out of it was COVERED in soot
steved said:Umm, it was a completely stock truck... smoking is sorta stupid IMO... and then they wounder why our trucks are getting emissions and fuels/oils are getting modified... :-laf
Forrest Nearing said:sounds boring... if you're making good power, you're going to have SOME smoke!!! even a bone stock truck will soot up the 1/4 panel... yours just got spread out over the entire underside of the truck, so it wasn't as concentrated
And yes I was underthere... but there was more a mess from my oil undercoating and no way to tell if it was soot or dirty oil...
steved
I would, but my truck came with an expensive hard shell tonnoue cover. It's the type that rolls up like a window blind. It rolls up right where the stacks would go.VIPERBLUELX said:way more drone dumped than with it exiting out the side, just put a stack on it![]()
