2nd Gen Non-Engine/Transmission Anyone running a DSS with a front hitch
Engine/Transmission (1994 - 1998) Exhaust brake and Auto
Engine/Transmission (1998.5 - 2002) map gone and no codes???
i've got a hidden hitch on the front of my '01
would like to put on a DSS and '03 track bar ...
anyone running the combo or know if it's possible?
I have the front hitch and DSS
I have both Warn front hitch and DSS installed on my 02. No problems.
Wiredawg
The DSS bolts on using the sway bar bolts, and basically wraps around the sway bar. As long as the your hitch does not use the same bolts, it should work.
By the way I have both the DSS and the trac bar on my truck. I highly recomend them, they made a huge improvement in how my truck drives.
I have the same hitch and a DSS on the shelf waiting to go on. I will post any problems when I get time to put it on but like McCram said it should be no problrm.
I was wondering the same thing, I just installed a DSS last Saturday verry easy install and it made a verry big difference on my truck, I actually like driving it again, in a straight line instead of all over the road.
Where did you guys get your warn front hitch from i am going to be in the market for one soon.
I would really like to see a picture of someones front hitch. I'm thinking of making one, since I have some scrap steel laying around.
McCRam said:
The DSS bolts on using the sway bar bolts... As long as the your hitch does not use the same bolts...
My DrawTite front receiver uses the sway bar bolts. I had no problem installing the DSS.
I think the original question was about installing both a DSS and a third-generation track bar on a second-generation Ram with a Hidden Hitch front receiver. I'd like to see that answered also.
Yeah, i have a u-haul front hitch and it also uses the sway bar mounts. I would like to run a DSS also so you got my atention. :D
