What WH6S Said
Oh, Yes It's Jet A-1 not B-1. My Bad
Moose00
CORed said:For those of you adding Waste Oil, do most of you filter it or do you let the oil sit for awhile in the drain pan and then pour out the top portion into a container to add to the fuel while leaving the bottom quart or two in the pan?
Doubleclutch said:Youse guys might consider checking out the Fleetguard FS20000 system. Fuel filter with nodules of lubricity boogers in the bottom designed for Cummins engines burning Jet A. The "lubricity booger" is a technical term I just made up, but you get the idea.
Greg
I run JetA all time mixed with biodiesel. It is great for thinning out wvo or biodiesel. Also when you get the right proportion of jetfuel to bio it seems to make the turbos spool up quicker than with just biodiesel.
