Anyone using an exhaust rake with a 727 or 518?
Lucas 300 HP Injectors installed
Tach
How effective is it? Which brake are you using? What does it do to your engine and transmission temps?
http://coffeewithJesus. homestead.com/web1.html 89 1-ton, Amsoil System 3000 5-30,K&N, cleaned-up exhaust with Dynomax straight-thru, rebuilt injector pump, thermostatically controlled twin 14" Permacool electric fans, intercooler, modified 518 OD transmission, Gear vendors OD controler, Reese Titan 2. 5" receiver, R-134 refrigernt, louvered front fenders, 93 aftermarket smoothie grille, new Dupont Chromacolor black, black-and-red rubber rubstrip, black headlights, powdercoated bumpers; 78 35'Avion, 93 Lance 900 slide in with generator and power jacks. To see my truck, Click on: <A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1169022&a=10097213
Jesus" TARGET=_blank>http://albums.photopoint.com/j/AlbumIndex?u=1169022&a=10097213
Jesus</A> saves!
As I understand it from talking to Bill Kondolay at DTT, it is not adviseable to use an exhaust brake on a first gen truck with the 727 or 518 trannies because the converter is not a lock-up converter and the brake will cause the transmission to heat up to much. from what I have reserched for my 93 auto you would have to convert to a 47rh transmission with lockup converter since the 727 & 518 can not be adapted for a lock-up converter as far as i know. It is either that or swich to a manual transmission(nv4500) or get 94 or newer truck. hope this helps a little. Bill's other good suggestion was to get a trailer with good brakes,(surgeis what he mentioned), or possibly electric.
Jim Curry
