I've attended a number of seminars given by the Bosch Distributorship in Las Vegas (Bosch is the manufacturer of our High Pressure Common Rail Pumps). About four years ago, Bosch was noticing a lot of problems associated with "dry fuel" or, ULSD without enough lubricity added at the refinery. At that time, Bosch was HIGHLY recommending the use of additives containing added lubricity. They sold Stanadyne but said, anything is better than not using a lubricity additive.
Then, at one seminar, the representative said nothing about using an additive. After his talk, I asked him about his lack of recommending an additive & he said that it appears that all the refiners are adding ENOUGH lubricity, now. Bosch is not seeing an unusual amount of premature wearing of pumps, anymore. Personally, I have not read of an unusual number of premature pump failures, either.
My guess is that this problem is not as significant as it used to be. The use of an additive or 2% B-99 for preventative measures is probably not a bad idea, though. But, probably not necessary. Lots of people, if not the vast majority of people, are running ULSD, only.
CARLACEE,
Two percent BIO is all that you need to "properly additize" your ULSD. Don't know if having an extra tank dedicated to the bio is worth it. That would be your decision. I have a 115 gallon, in-bed auxillary tank. With the main tank & the auxillary tank filled, you have about 150 gallons, on board. That's a lot of fuel & a lot of weight to haul around all the time. It's great on a trip with a trailer. I topped off my tanks in St. Ignace, MI. just at the north end of the Mackinaw Bridge connecting the lower penninsula with the upper penninsula of MI. I made it to the far nortwestern end of OK (Guyman) where I refilled the tanks (about 1530 miles). I still had about a quarter of a tank left in my main tank. I could have made it into NM but, at the time, some of the cheapest fuel was in OK so, I filled up there.
Your 100 gallon tank would only require 2 gallons of Bio to fully additize the entire tank.
Joe F.
