2nd Gen Non-Engine/Transmission Anyone using the Waytec fuse block from Geno's
Engine/Transmission (1998.5 - 2002) turbo
Engine/Transmission (1998.5 - 2002) Shifter Problem.
I am trouble shooting my edge comp no turn on when cold problem and want to get rid of all the fuse taps that are in the fuse panel by putting in an add on fuse block. Geno's has the painless wiring ones ,a bit spendy, and the Waytec fuse blocks.
What quality are the Waytec blocks and where do you guys mont the add on fuse blocks?
Any pics?
If you mean this Painless Wiring Kit, I have one that I have not had installed just yet. Looks to be a first class set up. The picture is different from what I got. Mine has two relays, one per 4 fuses as opposed the one relay. Also supplied were two 30 amp automatic resetting relays.
The hardest decision seems to be where to mount it. I was thinking of velcro'ing it to the top of engine relay box or mounting it above the PCM on the passenger side of the engine compartment on the fire wall.
Yeah... . :mad: I got tired of my wiring mess under the dash.
Jim
