Install the Pyro TC in the manifold to monitor EGT to keep form melting pistons. Max EGT pre turbo is 1250F. I would recomend the forward three cylinders whith engines with HX series turbos. Engines with HY series turbos it really does not matter which three cylinders you monitor
Mount the Pyro TC post turbo to monitor EGT for cooldown and the optimum time to shut the engine off to prevent oil cokeing in the turbo... shut down temp should be less than 350F.
MikeC, run form that dealer as fast as you can!
barry kelderman, um, read the above post!
