API and Dodge requirements, again
Yanmar 4LHDTE
HX35 Component Maps
Rather than foul up bmcwilliams' "Oil loss" thread, I thought it best if the oil quality aspect of the discussion was continued in another thread.
First, a quote from my '98 Service Manual, from page 9-3:
In gasoline engines, use an engine oil that is API Service Grade Certified (Fig. 3). In diesel engines, use an engine oil that conforms to API Service Grade CF-4 or CG-4/SH (Fig. 4).
Dodge were very explicit. Engine oils to be used in gasoline engines must display the API 'starburst' Certified symbol.
Just as explicitly, Dodge requires that oils used in diesel engines conform to the specified API service grade. Dodge did not require that only oils licensed to display the API 'donut' be used; they only required that the oil used *conform*.
Second, the API Service Grade Certified symbol has "FOR GASOLINE ENGINES" centered on it in bold letters. This is why no diesel engine oils are API Service Grade Certified.
Third, the 'Fig. 4' referenced in the Service Manual (on p. 9-4 in my '98 manual) is labelled incorrectly. The pictured symbol is the API Service Symbol.
Note that I included *no* manufacturer's names, no TDR members' names, and I have pointed no fingers and made no accusations.
I have posted the facts as I see them. If you have contradictory facts, please post them.
Fest3er
Oil War III - The Reckoning
This subject would make a great movie. :-laf :-laf
It has definitely succeeded as a great urinating contest :p
Signing off now, and riding into the sunset with donut-less oil. :D
Fest3er
I have checked my 2000 service manual and it does say that the gasoline engines must use oil that is "certified" by the API and shows the API label, but for the diesel oil it just says it must "conform" and does not show the API label. Man you need to be a lawyer to figure this C**p out. So the bottom line is that if you use oil that "conforms" to the spec's of your diesel engine that is all DC requires. You know if you just read it and did not think about it you would think it had to be licensed by the API, but per my DC service manual it doesn't. I am sure I have read your posts on this in other oil threads and it finally is sinking in. Thanks for the information and your patience with some of us slower members.
Bottom line is that Amsoil synthetic "conforms" with the API spec's and if you had an oil failure DC would have to prove that the oil did not conform and then Amsoil would cover you if that happened. Man it only took me a year to figure this one out :confused:
Re: Oil War III - The Reckoning
John,
I'm sure some old Farside cartoons could be found that exemplify the Oil Wars that have occurred here in the past. To be sure, I saw the humor in your post. That said, I would like to reiterate the purpose of this thread, just in case someone should ... overlook your humor.
This thread is not about pitting one oil manufacturer against another, nor is it about pitting dino oil against synthetic.
It is about what DC actually require us to use in our engines. And they have explicitly stated that any oil that conforms to the required API and SAE specifications can be safely used in our Cummins diesel engines.
That is the only point I am attempting to convey. And I will keep making that point, patiently and as gently as I can, until, as Pit Bull said, it sinks in.
Fest3er
WEll, yeah, but...
1. Define "conforms"
2. WHO gets to decide what does or does NOT conform,
3. WHO will pay the bill for SOMEONE to make the "conform" decision.
4. What variables will be allowed, or decide whether a specific oil "conforms".
I. E. If Brand "A" decides the required "conformance" standard is too limiting in regards to some specific anti-wear compound, and deviates from that standard, can Brand "A" STILL profess that THEIR oil "conforms" to the standard?
HEH HEH HEH - pulling my stirrer outta the pot and doing a disappearing act... :p ;) :D
White '02 HO Quad cab 2500 ETH-DEE, 3. 55's, Edge Comp, guages, Carter pusher pump... Drilled airbox/K&N... 285 HP/656 torque to the pavement. .
MOBILE amateur Radio - IC-706 MKIIG, 600 watt amp, 20/40 meters.
Gary based on your sig. it does not matter you are your own warranty station :D
The problem I see when DC put "Conform" is that it is now on them if they want to contest a warranty claim to prove that the oil did not conform. If they can prove that then the offending oil company will pay you big $$$ to sign a non disclosure along with the big $$$ check they will give you. ;) So you won't blab about thier problem oil.
Originally posted by Gary - KJ6Q
WEll, yeah, but...
  1. Who defines 'conforms'?
    I expect that 'confoms to the specification' means 'meets or exceeds the specifications'. Thus, if the spec called for the oil to neutralize a minimum of 3 deciliters of acid, and Brand "A" can neutralize only 90% of that (0. 9 x 3, or 2. 7 dL), then Brand "A" oil would not conform. However, if Brand "B" meets all the requirements and can neutralize one liter of acid, Brand "B" would conform, because it exceeds the specification.
    If Brand "C" meets all the requirements, but triples the amount of anti-wear protection, it would conform. But if Brand "D" has less than the specified amount of anti-wear protection, it would not conform.
    These are simplistic examples. The specifications are very likely quite complex, with multiple interactions between additives. Too much of one additive might lessen the effectiveness of another. That's why there are test specifications; running the tests according to their specs will yield repeatable, verifiable results.
  2. Who decides what does or does not conform?
    The published test specifications 'decide'. The tests show that either the oil meets or exceed all the requirements, or it does not.
  3. Who pays for the conform decision?
    We all do. It is built into the price of the oil we buy. The producer either run the tests themselves, or they pay someone else to run them, or they pay API. Whichever way, the costs are passed on to the consumer.
  4. What variability is allowed?
    I would expect that the specs state many limits in terms of 'at least'. Fr example, at least X wear protection, neutralize at least T acid. Other limits will be expressed in terms of 'not more than'. For example, not more than S square millimeters of wear scar. Others would be specified as an acceptable range, as in at least Y but not more than Z viscosity at D degrees F.
    If the standard tests show that an oil allows significantly less wear, neutralizes more acid and/or has viscosity near the high end of the range, then the tests prove the oil 'conforms' to the specification.
All oil manufacturers who want to maintain their reputations and sales will properly test their products. The Fly By Night Oil Company might produce a large batch of oil, sell it and close their doors. But they sure won't be around in a year or two when the failures start appearing. They could use all the proper API markings on their packaging, yet be nowhere to be found when the API goes after them.
On the other hand, the American Superior Internal Combustion Engine Oil Company, which has been in business for 50 years, produces a lot of engine lube, and has a large, loyal customer base, has a good incentive to continue producing oil that meets or exceed the required specifications and to continue testing their products to ensure they maintain consistent, high levels of quality.
Basically, it all boils down to ethics and honesty. An honest, ethical company will strive to produce products that meet or exceed the published specifications and will test those products to ensure product quality and consistency. The fictional American Superior Internal Combustion Engine Oil Company would be such a company. Whereas a dishonest, unethical company will throw ingredients together, deliberately mislabel and misrepresent their products, grab as much money as they can from unsuspecting consumers and try to be gone before the lawsuits begin; The Fly By Night Oil Company exemplifies this kind of business.
Almost any company that has been in business for a number of years and has a loyal customer base most likely is not skimping on product quality. But where does that leave new companies and new products? They haven't been around long enough to 'stand the test of time'. Do you take a chance on their products? Or do you give them a pass and go with the tried-n-true companies and products? In this respect, oil is no different from power-multiplying electronic boxes, super-duper turbos, fantastic clutches or indestructible transmissions.
It all still comes down to a personal decision. And such decisions *must* be based on as much factual information as is possible. My purpose with this thread is to clarify *one* particular piece of information that has often been greatly misunderstood in these fora.
Regardless of who makes the oil, who tests it, whether or not the test 'results' can be trusted, the oil we use must simply conform to the published specification(s). It can not be 'API Service Grade Certified' because that only applies to oils for gasoline engines. It does not have to bear the 'API Service Mark', because Dodge do not require that the API verify conformance to the specification(s). It simply must *conform*, and we have to trust the test results, trust the producers' reputations, and trust the choices our fellow oil consumers have made. Finally, we have to trust ourselves to make sound decisions.
Fest3er
"Gary based on your sig. it does not matter you are your own warranty station "
;) :D :D :D ;)
YUP - ya got THAT right!
AND, based upon the fact that past threads and polls have quite WELL demonstrated that oil related failures are EXTREMELY rare, I wouldn't hesitate for a heartbeat to use ANY of the better known synthetics in my truck - ESPECIALLY that dreaded "A" stuff... :p :D
I just can't yet stand the cost increase - OR the extended changes required to recover that cost - but I'm sure they're ALL very good stuff... ;)
AS it is, I'll soon be draining my 6-speed transmission and LS differential - and most likely refilling with the dreaded "A" stuff... :D
Gary why would you change the fluid in your 6 speed? The service manual states that fluid changes are not needed in the NV5600.
Wow you "A" guys have me convinced. Who needs to maintain thier oil change interval just to satisfy the warranty depart.
As I understand it, I can put this magical oil elixer in my truck and drive it into the ground and then drain it out and use it in every susequent vehicle I own! I can even will it to my son and he can start the whole process over again. Wow, I feel like I'm in that VISE GRIP commercial...
P. S.
Double Huh?
P. S.
Double Huh?
Let's not stray from the topic. This thread is about what oil Dodge requires us to use. It's not about extended drain intervals, 3K mile changes, magical elixirs or any other aspects of not voiding the warranty.
Thanks,
Fest3er
Yup, and the 5 speed has a "lifetime" lube! when the transmission melts down, that was its lifetime!
Gary is going to ignore that part in his book, I'm sure, and take care of his 6 speed. :)
Fester,
My hat is off to you, after taking a cheap shot on that other thread, and another on here, you kept you cool and kept with the facts and your posisition. Something I could never do.
I was "kidding" being "sarcastic", trying to be "funny", it's just like the manual states for the diff's for schle "A" that you don't ever need to change the fluid. But for Schle "B" you need to change the fluid every 15K miles. Who writes these service procedures :rolleyes:
Sorry back to the subject of earl ;)
Who writes the service procedures- Dunno but the lawyers must have something to do with it. And the marketing department. The "A" schedule is most likely put out for those doing the "cost of ownership" indexes. The fleet buyers, the consumer magazines and such. When you read the fine print- If you did not operate your vehicle exclusively between 68 and 75 degrees ambient, not towing, no city driving, no high speeds, no excessively low speeds, not in a dirty or dusty environment, no offroad, etc. (maybe a little restrictive but close :rolleyes:) Then you are on schedule "B"-- the real schedule. Just my take on the auto manufacturers marketing/CYA = A/B
"Gary why would you change the fluid in your 6 speed? The service manual states that fluid changes are not needed in the NV5600. "
YUP - and when I changed the manual transmission fluid in the 6-speed on my '98 Camaro SS at 500 miles or so, IT was full of fine brass particles, even tho' it was supposedly good for MANY more tens of thousands of miles... :rolleyes:
AND, a while back, one of the guys HERE posted a pic of the jellied lube/sealant down in the sump of HIS NV5600 - along with some even WORSE brass particles showing...
NOPE, at it's current 6000 miles or so, the stock lube comes OUT, synthetic is going IN... :p ;) :D
I'm not LIKE you rich young punks - I'm just a poor 'ol retiree - and MY truckss gotta last me the rest of my life... ;) :D :D
Sick man that I am, I actually enjoy these oil threads, as long as we stay away from the name calling and insults to personal intelligence and heredity.
I think the original post was pointing out that the words in the manual don't really prohibit oils that are not "certified" by any given organization. However, I've seen those same words used to argue against brand "A", or against synthetics in general; so that is what I'm really replying to.
One thing I find interesting about the "owner's manual requires... " type arguments is this: As noted above, the manual is very clear not only on what standards the oil must conform to, but also on viscosity requirements. I "must" use 15W-40 except in very cold weather. It is also clearly stated, either in the manual or elsewhere (like the Cummins web page) that synthetics are permitted after break in.
However, the #1 recognized synthetic in this country, by one of the most respected big-name oil companies, is Delvac 1 synthetic, which is a 5W-40. I decided in 1980 that I would use Mobil 1 5W-20 in my Honda, even though that was a clear violation of the owner's manual viscosity requirements. I got over 400,000 miles out of that engine, no rebuild. In short, I "broke the rules" on viscosity, and I came out a big winner for being willing to do that. (In later years, as 5W-30 and 10W-30 offerings became available in Mobil 1, I used those too. )
Do those who say I should not use Amsoil because of owner's manual statements about API certification/conformity, also feel just as strongly that I should not use Delvac 1 5W-40? It is, after all, the #1 synthetic oil, CI-4, SL, Cummins CES 20078 and numerous other ratings. And I don't think I can get it in a 15W-40. For that matter, this same logic would say I can't even use Valvoline Premium Blue, which is specifically developed with and recommened by Cummins, because it is also a 5W-40.
Even though I'm personally "breaking the rules" again and using Amsoil, I actually understand and agree with some of the concerns about Amsoil's marketing practices, and I understand those who don't want to risk going with a lesser-known company when there are excellent products available from Mobil, Valvoline, and other major players. But I don't believe you should use a legalistic reading of the owner's manual as the sole basis for that point of view, or you'll have to throw out the baby with the bathwater and would not be able to use Valvoline Premium Blue even though it was developed with Cummins and is an excellent product. (Similar statement true for Delvac 1 synthetic, Delo full synthetic, Rotella synthetic, etc. )
When I made my switch to synthetic a few years back, several of the companies HC mentioned, didn't even make one yet.
First choice was Amsoil, second was Mobil. The two LONG TERM players in the synthetic market, the pioneers, the ones that were laughed at, the ones who stuck it out, even though out of ignorance, mechanics said synthetics wouldn't work. .
It amuses me that the new "synthetics" on the market are accepted as "OK", becuase they are sold at Wal-Mart.
:rolleyes:
Point well taken, Sled Puller. For me, the choice is also between Delvac and Amsoil. Royal Purple, and others may be good too, but I just don't have any more time or motivation to research it further because I'm completely happy with the options already available to me.
I was mentioning the Valvoline product not so much because I believe in that one, but because of their clear connection as a "Cummins recommended" product. Rotella and others mostly because those are names that others would be well aware of and thus less likely to be scared of.
I realize the original intent of this thread was to AVOID brand comparisons, but interested readers might wanna check back threads on this issue - ONE of them recently pointed out that at least ONE reason Amsoil has resisted API certification, is the mandatory REDUCTION in some anti-wear compounds in the newer API spec'd oils - and even MORE reductions proposed fur those API certified oils on the horizon...
Reason? Our friendly tree-huggers and EPA - whose main interest is NOT on better lubes or longer engine life, but microscopic emissions THEY feel should be reduced, no matter WHAT it does in regards to engine wear...
It's much like the gradual shift to lighter weight oils like 5/40, not because they ENHANCE engine life or reliability, but because they reduce the internal drag on rotating engine components, delivering slightly better fuel mileage - again, an EPA influenced shift - and other than the slight benefit the thinner stuff delivers to colder climate users, that's about it for any real "advantage"...
