Thanks to blacksheepdiesel for illuminating my problem.
I dredged up this post in my effort to diagnose a no-charging problem. Unfortunately, my early research lead me to believe the alternator was at fault because I was getting no charging voltage at the PCM - where the red and black wires are separated by the 140 amp alternator fuse (which I also replaced for good measure).
Long story short - the culprit was the 2-wire plug on the back of the alternator. I didn't notice it was bad when I removed the stock alternator - I even looked. After buying an AutoLife reman alternator, with a lifetime guarantee but no refund policy, I still had no charging, so continued my research on TDR, which led to this thread and further inspection of said plug. Sure enough, one of the wires was broken away, right at the plug, so no chance for repair. I did try to repair it with the help of a work buddy who does electronic wiring harnesses. Even with dental tools and a lighted microscope, we couldn't get the pins out. So I bought a new one for $40 at the dealer, at least it was next day delivery.
The new plug come as a kit with the pins and rubber seals installed on 4 pieces of wire (different colors than the original). Why 4? Spares I guess. From there it's just a matter of mating the old wires to the new wires. I made careful note of the orientation first, then soldered and covered them nicely. It works! Hurray. I bought my old alternator back from the store for the core charge of $45.
Moral of story - Have old part tested if possible before buying a new part. This would have saved me $175 for a remanufactured alternator that I didn't need. So now I have an old spare.
Other moral of story - Had I wimped out and taken it to the dealer to fix a no-charging problem, they surely would sold me a bundle of parts, diagnosis, and labor and taken a week or more for the privilege. TDR saved me that much bacon and I learned some tech about my truck in the process.
P. S. In case you hadn't gathered it from previous posts, that "plug" serves to tell the PCM that the voltage output of the alternator is in spec. If not, the PCM protects the system by keeping the bad charge away.
