Engine/Transmission (1998.5 - 2002) APPS sensor voltage?
Engine/Transmission (1994 - 1998) FASS vs. Airdog
2nd Gen Non-Engine/Transmission Left-front tire eater
what are the correct voltages for the APPS? Mine only goes to 3. 5v at full throttle. Would this cause slow starting after engine is warm? Would it cause missing, hiccuping or jerking while trailer towing uphill? (overdrive locked out) I have those two problems and I think the APPS voltage should be 5. but I don't want to throw a new APPS at it if there is something else. P-codes are all clear. Ram 2500,AT quad cab, 4. 10 axle Thanks for any help.
The voltage at idle is printed on the back of the sensor. The sensor will not go to 5 at wot. It will not affect starting.
Thanks Bob.
Do you have any ideas as to the cause of the hiccupping pulling the trailer uphill? My slow starting seems to have fixed itself.
