APRIL 20th Meet 2
joe LV drag group pic at track?
hwy 95 rv stops ?4 hour b4 MM
Folks we are tryin' to keep a running count as to who's in (weather via E~Mail or on site)
So far we have ... ... .
(updated Daily)
TDR
RottnDogue
stg2500
BigDaddy
Snow man
Mopar-muscle ?
therabbittree
JLEONARD
Hammer
HEYBOSS
CTRam
Wheaties
HoleshotHolset ?
Local Scene
7 additional trucks
Again the Directions are... .
April 20th Saturday @
FROM NORTH OR SOUTH ON ROUTE 8
"Exit 15 CT-34 Derby"
Turn Right At End Of Ramp
1/10th Of A Mile And Keep To The Left
You will see TAILGATORS on the left at this point while you are at the light.
Turn Left On CT-115, Derby Ave And Go North For 0. 6 Miles to 326 Derby Ave
Driveway Is Just After An Empty Lot And Between Two Brick Buildings On The Left.
First Bay Door On The Left
There are very smalll numbers on the building at the entrance. There is also a sign for a custom counter and cabinet shop. <hr>
Truck Bio:
Y2K+1 3500 4X4 Quad Cab 4:10:1 LSD
Somewhat Powerpacked By Bank's (4 inch exhaust,High ram intake,~Minus~wastgate mod to 38 psi,~Minus~ottomind TLC +guages,K&N) ,Blue Chip Premium FMC DTT~93%TC~&~VB~TC Smart controller, Mag-Hytec's Double Deep Trans pan,DD injectors+Van Aken+Autometer Guages. ,Piers Modified PDR HX turbo,Enterprise Engine PerformancePusher pump setup Front End Leveling Kit from Jakit with 255/85R16 BFG http://www.bfgoodrichtires.com/ M/T's Custom Rhino Liner (see Tool Man's truck feature)DeeZee Black Diamond Plate Bed Rails And Tool Box , WAAG Side tubes with kick~outs Mopar Performance accessories-Sill plates-hitch cover-cargo aux lamp'n'Power, Hadley air systems 150 psi comp and air storage. DynaMat Sound deadening applied to entire cab and doors, Check out Tool's Stuff#ad
N. E. T. D. P
Tim,
You could be accused of talking to yourself. Start your own thread, then answer? I'm starting to worry about you :p
I'll try to be there whether we get to drill holes or not. Maybe we can bend some elbows?
Matt
Anyone coming from the RI-MA area wants to meet somewhere and caravan up?
Can anyone give directions from RI, what's the best route?
I'm close and can pick up 95, but from there!!!!!!!!!!!!!!!!!
Also Tim what you guys need? Beer, dough, what?
I might bring my drone with me:rolleyes:
CTram , C'mon now it's a TIM Popularity thang!!!
HeyBoss , 95 south until bridgeport (Exit 27 Rt 8N /25N ) Rt 8 North until ... ... ... ... ... ... .
I have a list of stuff to do around here as long as my arm. Saturday is the only day I have to do them. Need to do lots before Dyno Day May, 11th too. :(
Tough time of the year to give up a Saturday. :(
Originally posted by HEYBOSS
No I don't... ... ... ... ... ... ... ... ... ... But I have an elbow and wrist braker:rolleyes: :D :D
No problem HeyBoss, someone will have an elbow bender you can use. You're going to need it :cool:
Pusher pump , CHECK , Injectors , CHECK , Piers turbo , CHECK , Bank's Powerpack , CHECK , Remove Pack from powerpack , CHECK , T Conv , CHECK Valve body , CHECK , Van aken , CHECK , Bhaf , CHECK , Volant , CHECK , FMC , CHECK Dude stick a fork in me ..... I'm DONE! (Whatever). However a couple items on a few PSD'S might be in play here ! Well as of 2 O'Clock today I brought home my NEW Autometer FP guage wanting to put that in on the 20th ... ... ... ... ... BY 4:00 It was in ... . DANG! Soo Maybe we juuuust might take a HOLESAW to the white obnoxious money sucking wallet drain and plumb in that Volant!
I may not be able to make it on the 20th. I think that I may have to work.
I will let you know if I can make it later in the week but it does not look too promising.
O. k uhhh hmm????
origionally posted by admin after toolman tried to update top post<hr> The admisitrator has specified that you can only edit messages for 1440 minutes after you have posted. This limit has expired, so you must contact the administrator to make alterations on your message.
