“The only reservation I had with Archoil was their mileage claims. As with any additive, mileage is so subjective and depends on so many conditions, I don't think you can measure any effect using an additive”.
Sure you can.
1). Same route, same speed (60-MPH to end wind resistance problems), same load with same driver on 100% cruise control. Start/Stop from same fuel pump having run farther than what’s necessary to pump at least ten (10) gallons to avoid filling error. (200-mile loop).
Consecutive days with same weather. First day without, and second day “with”.
2). One also tracks all gallons consumed against the year previous. For the same gallons (against engine hours), what difference if any in the Average Annual MPG year-to-year.
90% of Americans travel to 90% of the same places 90% of the time.
Getting the driver out of the picture was Test One.
And getting placebo effect out is Test Two.
Fuel Additives are more easily seen as better combustion efficiency. The engine that hangs on longer before a downshift sort of thing.
Tell someone he’ll get better fuel mileage and he’ll drive worse than before.
Everyone wants something which automagically renders his poor habits moot.
For those who’ve gone to the trouble of getting out of the way of the truck (highest amount of constant-rpm “steady state” Town or Country), one can find better MPG with more energy put to good use (clean burn) via additives.
Are they good? Depends on if YOU are good.
Fuel burn is about degree & duration of input. Shorten BOTH of those to achieve the same end and savings appear. Fuel additives “work” when fuel burn is known. (Exactly).
Class 8 15L — or one of these diesel sports cars — it ain’t hard to tell once the baseline is known. In a late big truck one needs some “help” every 3-5,000/miles to clean it up again (very low idle time; higher means more often).
I run one of something fairly well constantly in the CTD. Doesn’t add much per gallon when no need for major clean-up involved (double dose).
Track percent idle time (or maintain above 27-MPH Average) and it’s not really an extra expense.
Power Service is fine. I prefer HOWES Diesel Defender as to availability and performance. Anything by SCHAEFFERs is gold, just harder to find without ordering
Diesel from high-volume truckstops (freshest) is always best action before anything else.
Sure you can.
