I was looking at this 33x12. 50R20 E/10 65 psi. tire, a Toyo M/T and at first glance of the specs I was interested but questioned the 114Q load index of 2600 lbs. thinking something must be a mis print.
I called Toyo and they confirmed. . no mis print. It is an E/10 ply tire with a rated load of 2600 ea @ 65 psi and are good to 99mph.
So the question is- If I don't overload the tire with direct weight how well will a 2600 lb tire perform in a panic stop with truck and trailer weighing in at 13K?
Kinda weird to see an E/10 tire with 2600 rating.
