Dieselnut59 said:The new (never used 2004 model) Yanmar engine smokes pretty good, even with nothing hooked to it.
BILLYGEE said:Just don't straight pipe 'er or you'll upset the neighbors when yur out dere blowin da snow at 4AM.![]()
TORQUE THIS said:Choco Milk is not a good stabilizer...![]()
HoleshotHolset said:Thanks for the comments, dudes.
I didn't have to do much to bolt it on. I used some 1/4" plate to make a bracket and used my flux-core wire feeder welder to glue it together. Trying to get the right sized belts was the biggest PITA... but it's all good in the end. The engine is significantly bigger than the old 7hp Tecumseh gasser... if you look closely at the pictures... you can see that the engine is wider than the snowblower 'chassis'.
I'll try to get a video/pics of it blowing smoke - and it blows quite a bit of smoke.
BTW, the engine block is aluminum - a magnetic block heater might not work too well.
Matt
biggy238 said:I'm screamin' hang a subaru turbo off the side of that thing and stud the head. See what it can handle. A twin turbo go-kart. yeah baby
biggy238 said:Build it like the old friction drive bush hogs that use a tire and a disk meshing for the 90* powertrain.
