Yesterday along with my injectors I finally did the stud installation on ole' Blackout.
The procedure was pretty straight forward. I followed the tech manuals recommendation as far as the sequence of torque goes.
I also went up in stages with torque on the injectors in 10lb increments until I reach 60lbs per stud.
I then went up to 75 ft lbs and then 86ft lbs then finally 96ft lbs. I used the ARP moly lube which is pretty slick.
I overchecked them at 96ft lbs several times and they were all holding the torque well.
The back rear drivers side bolt touches the "rocker box" and that had to be clearanced with a grinder to fit.
They sure do feel better than spongy OEM bolts!!
Next week I will probably do a retorque again
