Guess I should have added to my original post that I fuel exclusively at cardlock locations-generally I'm the only one around when I'm fueling. The location I use most of the time does have the gas pump right beside the diesel-but most of them have the gas pump far away to keep the 4 wheelers away from the "professionals"... . I never leave my truck while I'm fueling so odds of it getting stolen or having any problem are slim to none anyways.....
Lil' Dog hit it right on the head with the positive air shutoff. The Roda Deaco one that I run is actually a swinging disc so when it's latched open it's completely out of the airflow-I see a tick under 30 lbs. boost with my 275's and EZ so I'm pretty confident if it does restrict airflow it's real minimal... . Depending on the application they are either spring-closed or solenoid-closed. The spring-closed ones use either a manual pawl, air-tripped pawl or electric-tripped pawl to release the disc..... the solenoid-closed one (which is what I have) actually uses a big electric solenoid to swing the disc into place. When you clear the condition that actually caused it to swing (and clean your shorts out
) it's just a matter of swinging the disc back to the open position and you're ready for action again.
Mine senses engine RPM for automatic shutdown as well as having a big red manual toggle under the dash. The sensing deal is pretty neat-you tie into your alternator ahead of the rectifier bridge-the AC signal that is generated increases in frequency as the engine speeds up. So once you make the connection you unhook the butterfly, press the TEST button on the master box that makes it trip at 2/3 the selected RPM, bring 'er up with the throttle until you hit 2/3 of the speed you want, and turn the calibration pot until the light just goes out. To make good and sure you perform 1 more test at full speed and normal conditions to make sure it won't throw if you hit redline while racing a Duramax
. I tweaked mine about 1/4 turn after the red light went out so I can be sure that it'll kick in before the engine explodes-but still let me have redline for dyno runs and things of that sort... .
I try to remember to test mine about once a month-just throw the switch with the engine off and make sure the valve trips. Good for peace of mind as well as being part of the rules of the 'patch!
Any more questions fire away!
Jason
