I will change my ATF but only find the +4. I also find the "Universal" ATF Semi-synthetic, which covers 75% of auto trannies.
Should I drain the 6qts of +3 that is in there when I drop the pan/filter and add 6 qts of +4?
Should I drain out all 12 quarts of +3 (somehow) and filler her up with +4?
Should I stop performing oil changes and run the +3 in there till the trans burns up then begin to use the new +4 w/my rebuild transmission?
Should I use the "universal" oil?
+4 says it takes place of the +3 so it may be ok to mix them?
How about full synthetic +4? Can I mix that with the old +3.
I can only drain off 6 quarts w/an oil change. She holds 12 qt
Should I switch to Dexron III or IV like DTT recommends?
