Engine/Transmission (1998.5 - 2002) atf & filter change
Engine/Transmission (1998.5 - 2002) Marine Injectors
2nd Gen Non-Engine/Transmission 96 4wd steering box
I want to drop the pan and change the filter/fluid. How much fluid do I need to get the job done. Is there a way to drain most of the fluid out including the converter. The auto parts store said I will only need 4QT, on a system that takes 16 1/2 to fill I would think it would drain out more then 4qts.
